Cracking an electronic safe using brute force
Postby teatree » January 14th, 2013, 2:55 pm
Preface: There's nothing nefarious here, nor is the information contained herein particularly helpful to thieves or the dishonest. A thief would just cut the dang thing open and be done with it.
So I bought a fire safe to protect some documents that I wanted protected in the unlikely event of a house fire. When I got the safe, I promptly emailed myself the manufacturer's code, set up an easily remembered user code, and stored the manual with the manufacturer's code in a "safe place."
Fast forward two years. I need to get to one of the documents in the safe. I can't seem to remember the user code. No problem, I say, I'll just look up the manufacturer's code in my email. So, what keywords did I use to make it searchable? Apparently not safe, combo, password, combination, or any combination or related word thereof. Ok, no problem, I'll just go get my manual from... umm, nope, not in my drawer with user manuals, nor in my filing system. WTF. The combos are both lost for good.
So I start considering my options. I could send a notarized letter to the safe company, but where's the fun in that? I could open it destructively, but I didn't really want to do that either. The lock is an electronic combination with a five digit password, so brute forcing seems plausible, but there's a two minute lockout on 3 wrong combinations, taking the brute force time to 140 days. That won't work. Unless...
I open up the battery compartment, enter three wrong combos, it goes into lockout mode, I remove the battery for a couple seconds and put it back. Yep, it "forgot" it was in lockout mode, and I can now enter 3 more passwords. Only 99,994 more to go. I estimate the safe could be opened in less than 6 days using brute force. I'm not in a real hurry for the documents, don't want to break the safe, and love the challenge of getting my safecracking on, so I commit to cracking this sucker via brute force.
At first I considered a mechanical dialer that would punch the buttons for me, but the mechanics of doing that with acceptable speed seemed somewhat difficult - not an afternoon's kind of project.
However, by cutting away a couple globs of hot glue with a blade, i could access the keypad contacts directly:
Conveniently, there are access holes for connecting wires to the contact array.
So I start sketching up where I need jumper wires and placing them.
Then it was a simple matter of using some relay boards I had laying around to start dialing the keypad using an arduino I also had laying around. I used a couple of photosensors to read the LED status indicators so that I could know if the combo failed or succeeded. Finally, I used an additional relay to power cycle the keypad after 3 failed combinations to defeat the lockout feature.
With a little programming work, I had an automated dialer that should (!) stop when the correct combination was found. By logging each attempt on a laptop and writing a couple of little helper scripts, I had hourly status updates being delivered via email. It was a bit of a programmer's nightmare in that I could not test the code directly for success, and didn't have the exact details of what the success scenario looked like, for example, how long until the green LED would light, how brightly it would light, or if it would be solid or flashing. Some youtubing failed to turn up these details as well. So I did my best to make it robust to these details and prayed.
And prayed, and prayed, and prayed... for five days, the robot dialed, and failed, and dialed again. When over 2/3 of the keyspace had been searched and no combination found, I started to doubt the success of the project.
However, this morning at 7:09 am, one minute before my alarm usually goes off (weird coincidence), the phone on my nightstand buzzed with an email alert. It was the safecracking robot calling, saying it had found the correct code. Somewhat scared of a false positive, I showered first, then headed into the room and removed the heavy blanket which I'd been using to muffle the incessant beeping. I entered the code sent via email and lo and behold, it opened. You can see a pen propping open the door in the lower left corner.
I love it when a plan comes together. With a little hot glue the keypad will go right back together and the safe will be like new. And this time my email with the combination will not be titled "Remember this number". *facepalm*
Now, as a wisecracking friend said "Dude, you can totally rob a bank now, at least when it's closed for a week". And when they are using cheap Walmart fire safes...
teatree
Re: Cracking an electronic safe using brute force
Postby UAirLtd » January 14th, 2013, 3:30 pm
This is hacking at its finest: no frills, gets the job done. Also really well written. My hat off to you, sir.
User avatar
UAirLtd
Postby teatree » January 14th, 2013, 11:22 pm
UAirLtd wrote:This is hacking at its finest: no frills, gets the job done. Also really well written. My hat off to you, sir.
Thanks! The delayed gratification of this project added an element of suspense which really made it fun when it hit paydirt and the safe opened. It had to be truly autonomous as there was no way I could monitor its progress even after maximizing the rate at which codes could be entered and minimizing the downtime of the power cycle. I had all of that optimized down to 10 ms. That was all done through trial and error.
I got the keypad put back together this evening, and the safe is like new again.
By the way, what do you think I found inside the safe? That's right, the manual with the printed code. *facepalm again*
teatree
Postby leadacid » January 17th, 2013, 12:34 pm
[teatree], amazing story!
I had a similar experience when I started my last job. Locked tape safe. We had the key, but not the combination. That safe didn't lock out the controls after bad tries though. I ran the math on the combinations and found that it would take a guy, doing nothing but it, about 3 full business days to find the combination.
Ultimately we just got the guy I replaced to tell us the combination. :-)
leadacid
Postby Legion » January 22nd, 2013, 2:30 am
I just showed my friend this link.
He ran to his soldering iron like it's x-mass.
3 years ago he lost the combo to his wall safe.
Nice hack dude.
+1
User avatar
Legion
Postby teatree » January 22nd, 2013, 1:02 pm
I've gotten some requests for the arduino sketch I used in this project, so I'm posting it here.
It isn't pretty, but it got the job done. If you want to try this on your own safe, you're going to have to do some prep work: setting up the pins to your relays, calibrating the thresholds for reading the LEDs from your photocells, and you'll probably want to experiment with the timings to get it to go as fast as you can on your system.
I used CoolTermWin to log the serial output to a file so I could monitor progress over the days it took to complete.
Code: Select all
 * Brute force safe cracker for a Sentry Fire Safe.  It took me 5 days
 * to open my safe with this.  YMMV.  Have fun!
// map of keypad key number to arduino pin controlling the corresponding relay
unsigned char key2pin[10] = {
   9, // kp0
   2, // kp1
   6, // kp2
   10,// kp3
   3, // kp4
   7, // kp5
   11,// kp6
   4, // kp7
   8, // kp8
   12 // kp9
// arduino pin mapped to power cycling relay
unsigned char powerpin = 5;
int verbose = true;
// arduino pins mapped to photocells on green and red LEDs
int grnPin = 0;
int redPin = 1;
void setup()
   Serial.begin(9600);
   // Initialize key relays and power relay to open (high is open)
   int i;
   for(i = 0; i <= 9; i++)
      digitalWrite(key2pin[i],HIGH);
      pinMode(key2pin[i],OUTPUT);
   digitalWrite(powerpin, HIGH);
   pinMode(powerpin, OUTPUT);
// Read the status LEDs.  Return either the number of red blinks (the
// usual case), or that we got a green LED, which indicates a cracked
// safe.
int readStatus(double time, int& redBlink)
   // These values should be independently calibrated
   int redThresh = 200;
   int grnThresh = 200;
   int nsamples = 1000*time;
   redBlink = 0;
   int grnBlink = 0;
   // Count blinks via a moving avg and threshold cross
   int len = 10; // moving average length
   double avgRed = 0.0;
   double avgGrn = 0.0;
   double avgRed_last = 0.0;
   double avgGrn_last = 0.0;
   double redVals[len];
   for (int n = 0; n < len; n++) {
      redVals[n] = 0.0;
   double grnVals[len];
      grnVals[n] = 0.0;
   for (int n = 0; n < nsamples; n++) {
      // shift values to free up position 0
      for (int k = 9; k >= 1; k--) {
         redVals[k] = redVals[k-1];
         grnVals[k] = grnVals[k-1];
      redVals[0] = analogRead(redPin);
      grnVals[0] = analogRead(grnPin);
      double sumRed = 0;
      for (int k = 0; k < len; k++) {
         sumRed += redVals[k];
      double avgRed = sumRed / len;
      double sumGrn = 0.0;
      for (int k = 0; k < 10; k++) {
         sumGrn += grnVals[k];
      double avgGrn = sumGrn / len;
      if (avgRed > redThresh && avgRed_last < redThresh) {
         redBlink++;
      avgRed_last = avgRed;
      if (avgGrn > grnThresh && avgGrn_last < grnThresh) {
         grnBlink++;
      avgGrn_last = avgGrn;
      delay(time/nsamples*1e3);
   return grnBlink;
void turn_on()
   if (verbose) Serial.println("turning on");
   digitalWrite(powerpin,LOW);
void long_power_cycle()
   if (verbose) Serial.println("long power cycle");
   delay(5000);
   digitalWrite(powerpin, LOW);
   delay(400);
void power_cycle()
   if (verbose) Serial.print("power cycle... ");
   digitalWrite(powerpin,HIGH);
   delay(3250);
   delay(400);
   if (verbose) Serial.println(" done.");
void press(int key)
   digitalWrite(key2pin[key], LOW);  // CLOSE
   delay(100);
   digitalWrite(key2pin[key], HIGH); // OPEN
   delay(250);
// try all combinations of buttons we can press
void loop()
   int lo = 0;
   int hi = 9;
   int attempt_count = 0;
   int cracked = 0;
   turn_on();
   delay(500);
   for (int digit1 = lo; digit1 <= hi; digit1++) {
      for (int digit2 = lo; digit2 <= hi; digit2++) {
         for (int digit3 = lo; digit3 <= hi; digit3++) {
            for (int digit4 = lo; digit4 <= hi; digit4++) {
               for (int digit5 = lo; digit5 <= hi; digit5++) {
                  attempt_count++;
                  int redBlinks = 0;
                  if (verbose) Serial.print("Trying ");
                  Serial.print(digit1);
                  Serial.print(digit2);
                  Serial.print(digit3);
                  Serial.print(digit4);
                  Serial.print(digit5);
                  if (verbose) Serial.println();
                  press(digit1);
                  press(digit2);
                  press(digit3);
                  press(digit4);
                  press(digit5);
                  cracked = readStatus(2.0, redBlinks);
                  // 3 red blinks is a wrong combination.  5 red
                  // blinks is some mysterious error code.  When we
                  // get one of those, do a long power cycle to try to
                  // get things back to normal.
                  if (redBlinks > 3) long_power_cycle();
                  Serial.print(redBlinks);
                  if (verbose) Serial.println(" red blinks");
                  Serial.print(cracked);
                  if (verbose) Serial.println(" green blinks");
                  if (cracked) {
                     Serial.print("Cracked!  Code is ");
                     while (1) {
                  // We need to power cycle after 3 failed attempts to get
                  // out of lockout mode
                  if (attempt_count == 3) {
                     power_cycle();
                     attempt_count = 0;
teatree
Postby flink » January 23rd, 2013, 4:47 am
Thank you so much for sharing your hard work. It's something I could envision, but not carry out. :D
flink
Postby radu.motisan » February 10th, 2013, 2:56 pm
Excellent work, love to see such a project getting together. Unfortunately this doesn't go around the limited trial systems (3 wrong keys and you're out) nor the long keys (that require huge amounts of combinations and so time). Plenty of ideas for v2 :)
User avatar
radu.motisan
Postby teatree » May 29th, 2013, 12:56 pm
radu.motisan wrote:Excellent work, love to see such a project getting together. Unfortunately this doesn't go around the limited trial systems (3 wrong keys and you're out)
Actually it does exactly that, if you read it.
Right, brute force probably isn't the way on longer keys.
teatree
Postby TreyWolf » March 25th, 2016, 4:47 am
teatree wrote:
radu.motisan wrote:Excellent work, love to see such a project getting together. Unfortunately https://skinnyexpress.com/phen375-review this doesn't go around the Phen375 limited trial systems (3 wrong keys and you're out)
Lol, I like this. I read about a new spray that robbers use. They spray some film over the keypad and then can come back later and peel it off and can tell what buttons have been pressed by smudge prints.
Or another way is to put a mini camera facing the keypad. Your way is much more fun though thanks for sharing your hack.
TreyWolf
Return to Project Logs
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 0 guests
