Bluetooth appliance trolling
Postby jongscx » November 25th, 2014, 4:11 pm
Stuck in traffic the other day, I noticed someone's headphones were available for bluetooth pairing, it went away before I could try to actually do it, but the question remains:
How difficult would it be to have a device that constantly scans for unpaired bluetooth devices, connects, and plays an endless loop of Nyan-cat on the newly pair device? :mrgreen:
jongscx
Re: Bluetooth appliance trolling
Postby << \n » September 9th, 2016, 11:27 am
well, if you wanted a bodgey quick solution, all you'd need is some script that continually "presses" the BT scan button on your phone, and when it sees a device it connects with it. then route whatever you like through that connection. (e.g. script that loops nyan can). potential problems might be accidentally blasting yourself with nyan cat, or maybe connect to another computer and thus your system security / privacy is compromised (very bad!!). for the former problem, have a whitelist of your own devices to avoid, for the latter, either have solid crypto on everything you own, or you only approve connections with certain devices, or (and this is the draconian way do do it) not have any sensitive data on anything you own. (if you go bodgey, make sure you don't fall into the black hole of code spaghettification or topple the monolithic tower-of-piza / jenga -code, (also never compromise your freedom) i recommend a more thought through approach to this though, but it is do-able, and easy if you can coded) (this all assumes you have root access to your phone, if not, you could build a do it through a laptop with a dongle, or make a silly little dedicated device with a bluetooth module (which should be more fun if you like gadgets))
<< \n
Postby faari » June 2nd, 2017, 1:09 pm
If anyone has any ideas of how I can approach trying to get to the necessary information needed to make this useful for other project, then it would be appreciated. Maybe someone has already done the work?
_________________________
Kitchen Appliances
faari
Users browsing this forum: Yahoo [Bot] and 3 guests
