Space-based satellites help NASA researchers
Re: Space-based satellites help NASA researchers
Postby asheets » August 27th, 2014, 10:15 am
OK, I'll bite... as a former meteorologist, I can firmly state that we already collect more data than the computing power behind the meteorological and climatological prediction models can handle on a timely basis.
Postby mahdeen » September 18th, 2014, 11:44 pm
Once I had it open I had to remove the 4 screws (2 silver and 2 black) and pull the main pcb off of the lid. On the top of the pcb is the CPU and described in a previous post. The hope was that there would be test points (TP) on the pcb that I could tap into for serial communication.
_________________
mahdeen
mahdeen
Postby Osgeld » September 19th, 2014, 6:41 pm
you didnt notice the list of links to cheap pills in his sig?
op is a spammer
Osgeld
