Dreamplug solution vs. Arduino
Postby d0ugparker » February 7th, 2011, 12:52 pm
Dreamplug's new $150 solution:
http://www.gizmag.com/dreamplug-low-power-compact-computing-solution/17795
but is it worth the money--should I put my time and energy into an Arduino solution instead?
I'm just looking for comments.
TIA
DrDoug
d0ugparker
Re: Dreamplug solution vs. Arduino
Postby MS3FGX » February 7th, 2011, 1:28 pm
Well...this is absolutely nothing like an Arduino, this is a full computer in a very small form-factor. It's like asking if you should buy a laptop or an Arduino.
If you want to work on electronics projects, then obviously you would want an Arduino. If you wanted to do something like a light-weight server for your local network, you would get the DeamPlug (or one of the other very similar products based on the Marvell processor).
MS3FGX
