Real 4Kx2K output Quad embedded computer
Having a local hacker event? announce it here.
Postby dahlwoo » April 20th, 2016, 3:43 am
Based on the Rockchip RK3288, Quad Core Cortex-A17 @1.8GHz, supports Mali-T760 MP4 Graphics Processing, openGL ES1.1/2.0/3.0, OpenVG1.1, OpenCL, Directx11, and can 4Kx2K archieve 4kx2k H.264 and 10 bits of H.265 video decoding, 500% performance boost over Mali-400. On display aspects, the platform http://www.armdesigner.com/EM3288_SBC/ supports up to 18Gbps Data transmission rate and 4Kx2K@60Hz Video resolution.
The HD+ High Resolution IPS multi-touch 10.1" display technology features a crisp, clean and sharp 1280x800 High Definition display that is visible from virtually any angle.
EM3288 also supports Miracast which can project the screen to TVs, projectors, and streaming media players that also support Miracast. User can use this to share what you’re doing on your device, present a slide show, or even play your favorite game on a larger screen.
Specifications:
* Processor: Rockchip RK3288, Quad Core Cortex-A17 @1.8GHz
* RAM: 2GB
* NAND Flash: 8GB eMMC
* Interface: 3x USB Host, 1x USB OTG, 1x debug connector, LCD(LVDS, TTL, MIPI), Ethernet, HDMI, Audio, SD, RTC, GPIO, VGA, SATA, 3G, SIM
* Operating system: Android4.4.4, Android5.1
* Board size: 117.5 mm x 175.3mm
dahlwoo
Re: Real 4Kx2K output Quad embedded computer
Postby Armeto » October 7th, 2016, 12:23 am
dahlwoo wrote:Based on the Rockchip RK3288, Quad Core Cortex-A17 @1.8GHz, supports Mali-T760 MP4 Graphics Processing, openGL ES1.1/2.0/3.0, OpenVG1.1, OpenCL, Directx11, and can 4Kx2K archieve 4kx2k H.264 and 10 bits of H.265 video decoding, 500% performance boost over Mali-400. On display aspects, the platform http://www.armdesigner.com/EM3288_SBC/ supports up to 18Gbps Data transmission rate and 4Kx2K@60Hz Video resolution.
The HD+ High Resolution IPS multi-touch 10.1" display technology the bathmate features a crisp, clean and sharp 1280x800 High Definition display that is visible from virtually any angle.
Is this any good?
Armeto
Return to Events
cron
