Some wrongs occurred in the function of STM8
Postby ailexs » April 14th, 2017, 12:31 am
Hi~all,
I would like to ask help about STM809LWX6F, this is the STM809LWX6F's datasheet: http://www.kynix.com/uploadfiles/pdf8798/STM809LWX6F.pdf.
My program always flied and started again.The codes are as following:
#pragma vector=0x19
__interrupt void interrupt_handler_tim4(void)
    asm("SIM");
    TIM4->SR1 =0x00;
    Scan_Key();       // ( Invoking the subfunction, I think here has some problems;  The SCM is starting again)
    GC_Temp++;
    asm("RIM");
    asm("IRET");
char  Scan_Key(void)    // ( It can’t operate even it’s so easy)
    char  a,b;
   return a+b;
Do you know what it suffered ?
Thanks a lot!
ailexs
