Remote activated contactor with 5V coil
Postby edugimeno » December 11th, 2017, 6:03 am
Good morning.
Im trying to find a conponent that I can use to activate/deactivate a 220V line with my Arduino. I found this LADN11 contactor but it uses a 24V for the coil.
I would like something like this but with a 5V coil that I can drive directly with an Arduino, to drive external devices and on a DIN rail.
Has anyone seen anything like this before?
Thanks
edugimeno
Re: Remote activated contactor with 5V coil
Postby k-ww » December 11th, 2017, 6:48 am
Have you looked at the various solid state relay modules? They run from 5V an can switch anywhere from 1A to 20+A at 240VAC.
Look under "Solid State Relays & Contactors" at Farnell / Newark.
Postby edugimeno » December 11th, 2017, 7:23 am
Ok yes I had tried it, but I guess I had selected some filters wrongly...as I tried again to provide you with the results I got, and now I see some usable products....
Thanks!
edugimeno
