What is an MCQE128C
What is an MCQE128C
Postby Aries » February 25th, 2017, 1:05 am
Can anyone help me identify what this chip is?
Its clearly labelled but I cannot find any reference online as to what it actually is much less a data sheet by searching this part number. Is it possibly a custom part number or maybe some sort of short-form part number that doesn't appear in literature?
Any help appreciated...
Aries
Re: What is an MCQE128C
Postby bandersnatch » February 25th, 2017, 3:17 am
My guess would be a custom-flashed 48-pin version of the QE128 processor.
http://www.nxp.com/assets/documents/data/en/user-guides/QE128QRUG.pdf
http://www.nxp.com/files/microcontrollers/doc/data_sheet/MC9S08QE128.pdf
G$$gle "CE128" & look at the 1st few hits.
The other numbers on the chip probably relate to the packaging version, production date & flashed firmware version...
You can use a multimeter ("beep" meter) to check the pin connections for +Vcc, GND, IO etc. on
the PCB against the datasheet to confirm/refute this guess.
I dunno if you can re-flash this chip but the board will be useless for any other purpose if you can't re-flash the cpu.
STFB
Users browsing this forum: Baidu [Spider] and 3 guests
