Help finding potentiometer
Postby andrewcfitz » February 9th, 2017, 7:52 am
I have a whole house intercom, in which I believe the pots at each intercom are failing. Any time they are moved the sound cuts in or out. I am trying to find replacements, but I haven't found anything so far. Any help would be appreciated.
Thanks!
andrewcfitz
Re: Help finding potentiometer
Postby k-ww » February 9th, 2017, 8:21 pm
Please measure the size of the threaded shaft of the pot, and please post a pix showing the shaft that the knob goes on.
Postby andrewcfitz » February 10th, 2017, 5:28 pm
It has a 3/8" hole.
andrewcfitz
Postby k-ww » February 11th, 2017, 2:09 pm
Try looking here:
http://www.digikey.com/products/en/pote ... ageSize=25
There may be a slight problem: I suspect the pot you are replacing is audio [non-linear taper], and these are all linear taper pots.
Postby andrewcfitz » February 11th, 2017, 5:42 pm
andrewcfitz
Postby k-ww » February 11th, 2017, 6:40 pm
Sorry, the pots according to your photo are 500 ohms, not 500K [thousand] ohms.
I'd try these:
https://www.amazon.com/orlov-Linear-Tap ... udio+taper
You might need to use a washer or such to help fit it in the old mounting hole.
