Searching 3mm individually addressable RGB LED (eg WS2812)
Re: Searching 3mm individually addressable RGB LED (eg WS281
Postby st2000 » November 3rd, 2015, 3:04 pm
What's the purpose of the glycerine?
If the index of refraction is similar between glycerin and your light pipes more light might find it's way into the light pipes. Not sure you can get a glycerin tight seal around a square SMD part.
You probably can't find a 3mm part because there are 4 chips of silicon in each light. The chemicals are very different. For instance arsenic is probably used only for the red led.
Postby alanwangwang » November 22nd, 2016, 12:55 am
i think 3mm is really to small to package IC into the led , you can ask APA106 WS2813 LED manufacturer if they can produce it
alanwangwang
Postby ritola » May 3rd, 2017, 12:46 pm
I found two smaller surface mount individually addressable RGB LEDs, which may be suitable for you:
3.5mm x 3.5mm SK6812 SMD 3535: https://www.adafruit.com/product/2686
2.0mm x 2.0mm APA102 SMD 2020: https://www.tindie.com/products/dude860 ... bag-of-20/
ritola
Postby rene » May 5th, 2017, 1:46 am
ritola wrote:I found two smaller surface mount individually addressable RGB LEDs, which may be suitable for you:
Thanks for letting me know.
It's really through-hole LEDs I'm after :(
rene
Previous
