I am wanting to triangulate the location of a small helicopter in a room. The location information would be fed back to a computer, to identify where that helicopter is. What solutions can you suggest that should be simple enough to implement?
One solution I was thinking of is a flashing LED (IR or otherwise) on the underside of the helicopter and then have it so receivers that would pick up the location, but not sure if that would work?
