usie HP DV9XXX screen as desktop screen
Postby dr_nanotech » November 13th, 2012, 7:22 am
Hi everyone,
I would like to re-use my old laptop (dv9500t) screen as a "desktop" screen. I m not sure what protocol is this screen's connection tho...
does someone know if thee is hardware to do so ? or have any clue where to start ?
Thanks,
David
dr_nanotech
Re: usie HP DV9XXX screen as desktop screen
Postby semicolo » November 13th, 2012, 7:31 am
What's your background in electronics? These jobs are usually rather hard to do.
User avatar
semicolo
Postby dr_nanotech » November 13th, 2012, 7:45 am
Well, I think I can handle most of it ;) . If you have an idea, do not hesitate and i ll let you know if it's not ok for me :)
dr_nanotech
Postby asheets » November 13th, 2012, 10:49 am
Is the screen still hooked up to a working computer? If so, there are a variety of software implementations you can use to extend your monitor through a network.
asheets
Postby dr_nanotech » November 13th, 2012, 11:11 am
no, it is not, motherboard is dead ...
dr_nanotech
Postby st2000 » November 13th, 2012, 7:43 pm
If I had to guess, your Hewlett Packard dv9500t is probably suffering from a BGA thermal problem under the Nvidia graphics chip. HP caught a lot of heat (ha!) for it. If true, the fix to re-ball the graphics chip is rather expensive. The cheep fix is to use a re-flow heat gun and "carefully" apply heat to the Nvidia graphics chip. There are plenty of howtos on the web so I'm not going into it here. You might try that before you proceed with the "beheading" :).
-good luck
st2000
Postby dr_nanotech » November 14th, 2012, 4:06 am
Thank you st2000 for your answer but I don't want to repair it actually, I have seen a lot of stuff on the re-flow but not really interested in that ... yet. What i m asking is how i can re-use the screen.
Is there some hardware or process to make the screen , i dunno, DVI, HDMI, or VGA .... compatible ?
Thanks !
PS : I hope HP will burn slowly (as my laptop did).
dr_nanotech
Postby dr_nanotech » November 14th, 2012, 4:09 am
oh , and .... the beheading already occurred :D
dr_nanotech
Postby leadacid » November 14th, 2012, 2:01 pm
If you know the actual model of the panel, not the laptop, you can usually get a LVDS controller from China via eBay. Such as this one:
http://www.ebay.com/itm/LCD-Controller- ... 19d3ace066
Near as I can tell, that will directly interface with the LCD panel and give it a VGA input. The key thing is to know the actual panel manufacturer and model number. Usually that is obtainable if you take off the plastic laptop housing around the screen.
The problem with rolling your own solution is the intense complexity of doing so. Take a trip 'round Google for the topic you just posted and you'll see that people have been trying to do this for years, without much luck. It seems that these controllers have become available somewhat recently.
leadacid
Postby dr_nanotech » November 14th, 2012, 4:21 pm
awesome thank you ! that s exactly what i was looking for !
My google search always brought me the HP heat problems, I couldnt figure out the good key words for my search
this will help a lot and get me started ! thanks
i will now look for a good how to or some examples.
Thx LeadAcid
dr_nanotech
Return to Help me! Hardware
Users browsing this forum: heater and 6 guests
