Contradicting myself above, repeated rough treatment had caused it to become a bit unreliable and shut off unexpectedly occasionally. So the first mod was to mount the processor on a proper PCB.
20 minutes with Inkscape and a vernier calliper produced this ...
... which after a further 40 minutes with a toner print, the clothes iron and some past-its-best ferric chloride turns into this:
A postage stamp sized board with all the loose components soldered down neatly. Here we have: AVR, 3.3V regulator, two SM resistors for the USB data wires, some smoothing capacitors salvaged from a dead hard disk and an 8MHz crystal, the only component requiring holes to be drilled.
Actually, picking apart the rat's nest of transformer wire and resoldering everything took another couple of hours, but it was worth doing it right.
And here it is all repacked with a little less hot glue this time:
Pictures of this year's car build can be found here.
