Temperature controller for laminators
Postby Oiphorie » August 1st, 2016, 3:00 am
recently, I read about the toner transfer method for making PCBs by simply print the layout, put it together with the PCB and heat it up, so the toner sticks to the copper.
I wanted to try this method, so I bought a cheap laminator for about 20 bucks and wrote some code for a PIC 16F1824. The result is great!
The small sized PCB of my control is made by using the toner transfer method
Prototype with PCB version 1
heat up
cool down
If you want to make your own control, I uploaded everything needed below.
BE CAREFUL, YOU WILL BE WORKING WITH DANGEROUS VOLTAGES! REPLICATION AND USING AT YOUR OWN RISK!
UPDATE: added layout files which can be edited by using Abacom Sprint Layout 6
layouts_final.zip
Layouts to be edited by using Abacom Sprint Layout 6
(89.5 KiB) Downloaded 30 times
laminator_control_2016_08_26.zip
(970.08 KiB) Downloaded 91 times
layout_with_MOC3040.zip
(960.91 KiB) Downloaded 95 times
Oiphorie
Re: Temperature controller for laminators
Postby AlanVasquez » March 29th, 2017, 4:07 am
Amazing one!
AlanVasquez
Postby Oiphorie » April 29th, 2017, 6:38 am
I added the layout files, so it's easier to change something, if necessary.
I'm using Abacom Sprint Layout 6.
Oiphorie
Postby WilfredK » October 18th, 2017, 12:56 am
Oiphorie wrote:I added the layout files, so it's easier to change something, if necessary.
Thanks Oipherie, this is awesome!
WilfredK
