I have an LCD view finder from an old JVC VHS-C camcorder. The main chip is the SONY CXA1854AR, implemented with composite input. The LCD panel works perfectly. I'm still working on the backlight. Has anyone ever messed with one of these LCD viewfinders? Any good suggestions for an application? Helmet mounted display/night sight come to mind.
This has been the result of much continuity probing and datasheet studying.
I will try to get an action shot up as soon as i can rig a useful backlight.
Edit:
CXA1854AR LCD decoder/driver
http://www.alldatasheet.com/datasheet-p ... 854AR.html
