A few small activites I did today *56k warning*
Postby hak8or » August 13th, 2011, 2:55 am
**Under each picture is the link to the full res picture**
First thing was fixing someone elses radio. The backlight for the car radio was lit using some filimant based tiny light, which burned out, and there was no voltage present after I removed the bulb, so I decided on putting in a LED instead.
For some reason It was near impossible to get the led out, the solder on the PCB refused to melt and let go of the leads of the bulb. Don't know why, but after a few minutes I finally got it out. After the bulb finally got out, I had to fit a tiny set up becuase there was barely any room between the plastic case and the PCB. I used a small basic free form circuit, using the leads of the components to hold them in place. The negative pin of the LED is attached to the hole that was meant for the negative pin of the bulb. Then the positive lead of the LED goes to a resistor, which goes to a wire that I managed to find a hole for, goes to the other side of the PCB, and gets attached to a 5V bus I found on the board.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250006.JPG
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250007.JPG
I found a BGA chip on my desk, and noticed that the solder balls were missing on it, so I decided to do a quick reball. First ever time I did this, so forgive me if I did a horrible job. :P
Before re balling:
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250010.JPG
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250011.JPG
Fluxing up for re balling:
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250020.JPG
After re balling:
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250021.JPG
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250023.JPG
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250027.JPG
After that, I started to take apart the water chiller thing and see what I could do with it. One thing I noticed was the way the water was cooled and heated.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250028.JPG
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250029.JPG
Big metal pot that is used to cool the water. It was surrounded earlier with Styrofoam and a lot of tape, but I took it off to see what the actual chiller looked like. The tube at the top is a place for water to go if the chamber over flows.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250032.JPG
That is how it looks under the top of the unit. Above the picture is the chamber that I just mentioned earlier. From what I see, water flows into the top chamber, gets cooled or left alone, depending on the temperature, and then flows into the lower chamber. On the right of the picture you can see the heating chamber, it is wrapped with some sort of insulating foam to prevent heat from escaping. The top two "ports" are connections to thermostats that sense the temperature of the liquid inside. Under those two "ports" are four connections to what I think is the heating element. I was unable to take apart this chamber, hence so little information about it. The tube that is in the middle of the picture is wrapped in a sort of foam, also for insulating the tube.
What strikes me as the tube being inefficient is the way that water travels. The water is stored in a massive plastic tub onto of the unit, those 55 gallon plastic tank things that are usually see through. Lets say you want cold water. The water from the tub (room temperature) travels to the cooled chamber (cooling itself), then through the heating chamber (heating self), and then into the faucet for cold water. What about if you want warm water? The water travels from the tank (room temperature), into the cooled chamber (cools self), into the warm chamber (warms self), and finally the warm faucet. In both cases the water goes through an unnecessary temperature change.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250036.JPG
This is the cooling chamber without some of the stryofoam.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250038.JPG
This is another wierd thing I saw that could have been improoved. The only way the coils take away heat is through the tiny contact point between the metal chamber and the copper tubing, which is not much area to transfer heat at all. Why have they not done something else, for example used a heat conductive gel between the tubes and chamber, or something like that to increase area for heat absorbtion? I ran the unit for a few minutes to see the frost on the tubing. I am a sucker for frost, what can I say? :P
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250039.JPG
More frost at the base of the compressor. If I understand phase change systems well, if the system is designed well, there should be no frost that close to the compressor. Though I may be wrong about that.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250040.JPG
More frost.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250041JPG
Ahh, never can one have too much frost. :P
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250042.JPG
And the last picture, frost building up inside the chamber.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250044.JPG
I am planning on getting another chamber around the coils and the original chamber, so I can pour a medium in between the chamber and coils. I am thinking anti freeze or something like that, since air is a horrible heat conductor compared to such liquids. Hopefully that will make the cooling effect more extreme. Overall the unit when chilling uses up 240 watts. I did not get to mess with the heating element of it yet, but while playing around with the unit I did unplug the heating element to avoid things overheating (no water in the unit).
And here is my desk in the aftermath of these things I did today.
http://8486.a.hostable.me/pictures/Basement_8-13-11/P1250049.JPG
Hope you guys enjoyed the pictures. :)
hak8or
Re: A few small activites I did today *56k warning*
Postby MS3FGX » August 13th, 2011, 7:45 am
This was probably the most interesting thing I have seen all day, thanks for posting.
MS3FGX
Postby hak8or » August 13th, 2011, 10:29 am
MS3FGX wrote:This was probably the most interesting thing I have seen all day, thanks for posting.
I have been looking at your website, and it is fantastically done!
I was considering posting this on my web host and then just linking to it from hackaday, but I did not want to mess around too much with making a blog using word press on it. Very well organized and clean.
Unfortunately, for various reasons I was personally unable to follow this bit of advice and instead relied on one-off battery packs, hacked together wall-wart style DC adapters, and other unreliable and largely ineffectual means of powering my projects. There was a very dark period in which all of my projects had to run off of one brave little 9 volt battery.
I had the exact same problem a few years ago! It was mostly wall warts for me, or getting power out of the board of some other device, and it looked horrible. Then I found out about making my own PCB's and I am currently working on my own power supply board. Switching style. :P
Very jealous you got into the testing phase for the google laptop, I tried to get into it to but they rejected me. Excellent review though.
Also, the Bluetooth sniffer at your window is awesome, I never saw someone do such a thing, it was always just war driving using wifi instead. :P
Excellant website, very well orginized, and simplistic, it is awesome.
hak8or
