UK 2 pin plug
UK 2 pin plug
Postby benj111 » February 1st, 2018, 8:28 am
I'm just getting into electronics and I've ordered myself a soldering iron.
It came with an EU plug and one of these things
essentially a uk plug without an earth pin.
(to non uk readers, the earth pin is required to be inserted first to unlock the other 2 pins).
So how am I expected to use this? stick a screwdriver in the earth pin socket to plug this in (an electrical screwdriver, for safety obviously). or is this a case of someone reading the spec sheet for uk plugs, but cutting one corner too far.
Interestingly the iron also has a working led hidden under an opaque case. Presumably so that the magic electric fairies can see.
Anyway I found it amusing :)
benj111
Return to General Talk
