ARM Cortex-A9 quad core solutions
Postby winy » March 2nd, 2017, 11:48 pm
1. NXP/Freescale i.MX6Q embedded Single board computer/development board
http://www.forlinx.net/products_detail/ ... Id=68.html
1) its SoM is only 60*70mm
2) single board computer carrier board pin diagrams
OKMX6Q-C single board computer consists of carrier board and CPU module FETMX6Q-C. The carrier board was designed as a 4-layer PCB and on-board connectors such as Gigabit Ethernet, CAN bus, parallel cammera, WIFI&BT, etc. What's more, the CPU featured MIPI, MLB and EMI are also drawn out. Tested by EMC and high&low temp to guarantee the SoM to run stable in harsh working environment.
OKMX6Q-C Carrier Board
Audio:1x phone, 1x MIC, 2x speaker
Key: 3x key
IIC: 3x IIC
DIP: for setting up of booting mode
SPI: 3x SPI
Reset:1x reset
CAN: 1x CAN
PWM: 4x PWM (1 for backlight)
MIPI camer: 1x MIPI camera OV5640
LCD: 1x LCD resistive/capacitive
DVP camera: 1x DVP camera OV5640, 5.0Mg
EINT: supported
SD/MMC/SDIO: 2x SD/MMC/SDIO
GPIO:Supported
USB Host: 2x USB 2.0 host
LVDS: 2x LVDS
USB OTG: 1x USB2.0 OTG
HDMI: 1x HDMI
Ethernet: 1x Ethernet 10/100/1000M
MIPI Display: 1x MIPI
UART: 5x UART (1x debug, 3x 3-wire, 1x 5-wire)
SATA: 1x SATA
IrDA: 1x IrDA
EIM : Supported
Power Adapter: 5V
3G/4G: mini PCIE interface
RTC : CPU RTC and on-board RTC
WIFI&BT: 1x WIFI&BT
ADC:external expand resistive touching controller, empty solderred
JTAG: Supported
2. Samsung Cortex-A9 quad core development board S5P4418
S5P4418 single board computer is a Cortex-A9 quad-core development kit with main frequency of 1.4GHz, 1G DDR3 and 8G eMMC, on-board SPI, RS485, CAN, UART, LVDS,HDMI, MIPI, Gigabit Ethernet are all ready-to-use for developers. What's more, expand modules like MIPI camera, DVP camera, WIFI&BT, 3G/4G are also available. Sleeping and waking up modes are more conveniently to users.
SoM dimensions: 60*45mm, carrier board dimensions: 190*130mm
PCB layer: 4-layer carrier board OS: Android 5.1
On-board connectors:
Display: 1x RGB LCD, 1x LVDS, 1x MIPI, 1x HDMI
Camera: 1x DVP, 1x MIPI
USB: 2x USB2.0 host, 1x USB2.0 OTG
UART: 5x UART (4x TTL, 1x RS232)
IIC: 3x IIC
SPI: 1x SPI
Ethernet: 1x 10/100/1000M
WIFI: 1x WIFI
BT: 1x BT
RS485: 1x RS485 (with isolation protection\0
mini PCIE: 1x mini PCIE for for 3G/4G module
IrDA: 1x IrDA
user key: 6x user key
comparing the two different quad-core boards, the i.MX6Q is a little more expensive but a longer product lifetime, while the S5P4418 is a high cost effective item which is more applied for commercial devices and tablets.
winy
Return to General Talk
