SMT Solar Charger
SMT Solar Charger
Postby HucksleyWethershire » February 5th, 2013, 7:31 pm
I saw this while reading a kickstarter
https://s3.amazonaws.com/ksr/assets/000 ... 1344432786
It is the control board for a 15W solar panel that keeps the device plugged into it (ipad, iphone,etc) from frying.
It looks like bunch of resistors and two ICs but I can't identify them from the picture.
Any idea what those ICs might be?
http://www.kickstarter.com/projects/761 ... er-station
HucksleyWethershire
Re: SMT Solar Charger
Postby UAirLtd » February 5th, 2013, 7:47 pm
One of those is a SMT diode (it's marked D1), probably ultrafast or schottky given the nature of the device. U1 is almost certainly a standard 5V buck converter IC (probably with UVLO), of which many many exist and all pretty much do the same thing: provide a regulated DC output from a DC input.
I don't think it does anything fancy like MPPT (and therefore I dispute the claim that "SunVolt performs very efficiently") because with a fixed 5V output that you'd need to ensure compatibility with devices, you don't have the option of doing any kind of current control.
User avatar
UAirLtd
Postby HucksleyWethershire » February 6th, 2013, 2:17 pm
That's some impressive skills.
I found some cheap chargers on goldmine electronics (surplus store :D ).
I'm not sure if I want to mess around with trying to make an MPPT charger, they look bulky.
I think i'll try to charge a rechargable battery before I try anything with my iphone.
HucksleyWethershire
Postby HucksleyWethershire » February 7th, 2013, 5:59 pm
How would MPPT work with a phone or laptop?
HucksleyWethershire
Postby UAirLtd » February 7th, 2013, 7:58 pm
In an instance where you're using just a PV panel to charge one unmodified phone or laptop, then you can't. As I mentioned, with a fixed 5V output (or whatever voltage your laptop uses), you don't have the option of doing any kind of current control, therefore MPPT is not possible.
But if you were to attach a battery pack to the PV cell to buffer the energy, then you would be able to use MPPT. Alternatively if somehow you were able to access your phone/laptop's charge controller to allow variable charge current, then MPPT could be implemented.
Many smartphones for example can select between two or three charge rates depending on whether they're connected to a USB 2.0 port, wall wart, or something proprietary, one way of "hacking it" would be to have the PV panel toggle the smartphone between these three charge rates, to achieve some approximation of MPPT.
If you're interested in MPPT, then probably attaching a battery pack to the PV cell would be the wisest choice.
User avatar
UAirLtd
Postby DtommyD » March 21st, 2013, 10:27 pm
Sounds cool but with all technical achievements aside, iPhones (or any rechargeable) don't like to be interrupted while charging. Of course you can. I'm saying long term battery wise. Every time a cloud goes over it would stop and start. I agree above. Thats what batteries are for. Maybe for an emergency I guess.
DtommyD
Postby Fitzgerald02 » April 25th, 2013, 3:00 am
I think this is right place for getting some new ideas about the Electronics, So I also want to know how we can charge the smoke alarms and some other wireless security alarms batteries with the help of solar panel.
Cave Secure Alarms
http://www.cavesecure.com.au/
35 Fallbrook Street Kenmore Brisbane QLD 4069 Australia
Phone: 1300 299 937
home alarm monitoring brisbane
Fitzgerald02
Return to General Talk
Users browsing this forum: Bing [Bot], Phoenix and 5 guests
