Bluetooth Teensy like board?
Postby BlueCoder » December 25th, 2012, 1:57 am
Are there any dev boards like the Teensy but for Bluetooth?
The Teensy is a perticularly useful board for converting old keybaords, joysticks, and gamepads into USB. For example converting an old IBM M series keyboard.
I'm wondering if there is any generic dev platforms for Bluetooth? There are a number of devices I wouldn't mind converting to Bluetooth. Would be nice if it could support any type of Bluetooth device. Not a generic serial port.
BlueCoder
Re: Bluetooth Teensy like board?
Postby tamarok » December 25th, 2012, 7:26 pm
I haven't seen anything yet, but in the meantime you could uses a Bluetooth module. For example, as described here:
http://stafava.blogspot.ca/2012/12/conn ... odule.html
tamarok
Postby MS3FGX » December 27th, 2012, 6:07 pm
The AIRcable SMD comes to mind, it's a fully programmable microcontroller and Bluetooth module on one board. But you have to program it in BASIC, so be warned.
Like already said, pairing a MCU up to a standard Bluetooth module would probably work just as well, but then you might have issues with which Bluetooth services are supported.
MS3FGX
Return to General Talk
