3D printer remake to Laser engraver
Postby BoKKeR » October 16th, 2015, 11:00 am
Hey guys I am looking forward to buy a cheap 3D printer but I want to use it also as a laser engraver, my basic idea is to get a cheap 3D printer and a 40$ laser, make some holder for the laser and make it easy to change, not sure if its possible, and not sure how much laser power I need to engrave OR cut wood which might be a option too to implement. I did not buy anything yet I am just planing. so the question is, what kind of problems could i encounter. laser output power needed to engrave to wood or cut wood: is it possible to get a 1W laser power it with half power to engrave and maybe full power to cut wood ? any other printer/laser that are better for this project?
laser probably:
http://www.aliexpress.com/item/High-Quality-1PC-450-500mW-Violet-Laser-Module-With-Holder-For-Mini-Engraving-Machine/32442077024.html?spm=2114.01020208.3.58.9yBMJ9&ws_ab_test=searchweb201556_2,searchweb201527_4_71_72_73_74_75,searchweb201560_9
3d printer probably:
http://www.aliexpress.com/item/Hot-Full-Acrylic-Quality-High-Precision-Reprap-Prusa-i3-LCD-Acquired-DIY-3d-Printer-Kit-with/2026704108.html?spm=2114.01020208.3.1.wXjnEw&ws_ab_test=searchweb201556_2,searchweb201527_4_71_72_73_74_75,searchweb201560_9
BoKKeR
Re: 3D printer remake to Laser engraver
Postby BoKKeR » October 17th, 2015, 7:55 am
wow I choose bad category can someone move it ?
BoKKeR
Users browsing this forum: Bing [Bot] and 4 guests
